Rear brakes will not bleed
Old Oct 12, 2008 | 01:27 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I replace the line from the prop valve all the way back to the calipers. I put in Earls SS lines at the flex points so nothing should be collapsing.
Anyway on Friday I tried a gravity bleed. I filled the resevoir and left it uncovered. I losened and later removed the bleed valve from the caliper. After 4 hours nothing had drained from the resevoir. Today I had my wife help me do the traditional pump the brake method and still no fluid would drain from the resevoir. Thinking that I had broken the master cylinder when I bench bled it, I took off the cover and had her push the pedal in which created a nice little gyser.
I decided to try the front brakes. Right now they are being gravity bled with no problem at all.
Any ideas on what I can do about the rears?
Old Oct 12, 2008 | 02:23 PM
Car: 92' RS
Engine: LO3
Re: Rear brakes will not bleed
Well nevermind. It started bleeding now. Not sure what the problem was though.
Old Oct 12, 2008 | 03:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It takes a while to fill all that tubing.
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
