Brake lights don't work
Old Nov 9, 2008 | 03:48 PM
Vincez28's Avatar
Car: White 1985 z28
Engine: 305 4b carb
so i went out for probably the last cruise on thursday before the car gets put away for the winter, and my buddy noticed that my brake lights dont work, i checked my fuses and everything ok, then i noticed the brake light switch under the dash and there should be 2 seperate plugs that plug in to the switch that were not connected??? anyways the plug closet to the brake bracket accepts the orange and blue plug that i found under there and then there's another plug with a purple and pink w black stripe. so i plug in the first plug orange and blue and the brake lights now work. but what is the other plug for? and does it matter which way it plugs in?
thanks,
Vince
Old Nov 9, 2008 | 06:40 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Brake lights don't work
The other should be to disengage the cruise control if I'm not mistaken (if so equipped).
Old Nov 9, 2008 | 06:48 PM
Vincez28's Avatar
Car: White 1985 z28
Engine: 305 4b carb
ok thanks, i don't have cruise control so i guess it doesn't need to be plugged in.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
