Hydraboost or c4?
Old Nov 25, 2008 | 11:10 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Hydraboost or c4?
I'm drawn on wether to go with a hydraboost/4th gen master setup or corvette booster/master. I'd like a very responsive & firm setup which I won't get with hydraboost, but my plans include heavy turbocharging and I don't want to run a vacuum pump. I also plan on swapping in a rack & pinion which will put extra demand on on the power steering pump with hydraboost. Oppinions?
Old Nov 26, 2008 | 12:17 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: Hydra-boost or c4?
go hydra i don't know what you know but every hydra vehicle Ive driven stopped firmly and was almost excessively responsive. The rack isn't going to draw on the power steering system to much more then stock.
Old Nov 26, 2008 | 12:47 PM
bl85c's Avatar
Car: '85 maro
Re: Hydraboost or c4?
Hydraboost just has a different feel to me, kinda like improperly bled brakes. Of course I've only driven 6000lbs trucks with hydraboost, I'm sure it feels different in a light car.
Old Nov 29, 2008 | 05:32 PM
anthony714's Avatar
think future..if youre going big engine low vacuum get hydroboost...anythign less than 15" vacuum counts a vacuum booster out..you cant use reseve canisters because all that does is store up morevacuum which isnt enough to start with...say you had 10" at idle.you can have 3 canister and all u have is 3 canisters with 10" vacuum..still wont help......
i currently use a vacuum pump and its so so..for basic street driving its ok..uses a lot of voltage abut pulls good vacuum..im going hydro next year
as far as tasking system haaaaaaaaa that 6000 truck you drive uses same system and workes just fine and yore askng it to do more than your camaro will ever be asked. the only thing you may want to try to do before installing stuff is find a power steering pump with a resovior with 2 returns..most desiels with hydroboost have them.theres discussion that you should use 2 seperate returns....maybe maybe not. hydrodyne is a big supplier and they just t-off their return and say its fine.
Old Dec 1, 2008 | 12:21 AM
bl85c's Avatar
Car: '85 maro
I was just going to braze another fitting on my stock pump. I was looking at the specs and it looks like a good match as-is. I already have a hydroboost off an astro waiting to go, I just need to mess with the pedal rod and get a mc.
sfmaro
Brakes
189
Jan 27, 2017 10:26 PM
tomsaddy
Brakes
Jan 25, 2015 10:38 PM
mcfly89
Jun 30, 2014 11:17 PM
Killert
16
Mar 4, 2014 04:29 PM
dhirocz
Aug 24, 2011 04:58 PM
