Stuck brake caliper?
Old Dec 7, 2008 | 02:41 PM
xTIMBERxWOLFx's Avatar
Car: 1991 Pontiac Firebird
Engine: LO3 V8-305 5.0L TBI
Transmission: Automatic
Axle/Gears: Stock
i have a 91 firebird 305 tbi and i hear a bad squeal. i took the passender side tire off and no problems.. the rotor spins fine without a hitch.. i took the driver side tire off and i found the problem with the squeel. apperently the brakes are really snug on the rotor and when spinning the rotor makes the bad squeel.. the brakes are almost brand new.. it is more difficult to turn than the passenger side.. can you guys tell me how to fix that? lol
Old Dec 7, 2008 | 02:45 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Re: Stuck brake caliper?
sounds like a bad caliper.
Old Dec 7, 2008 | 03:01 PM
Axle/Gears: Stock
lol i was afraid someone was gunna say that
Old Dec 7, 2008 | 03:31 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Whe where the calipers last replaced? It could be a caliper, but also could be the rubber line going to the caliper. I replaced the calipers and brakes to only find the rubber hoses had started to seperate on the inside causing one caliper to stick. Replaced my rubber lines, and now i have even straight line braking. - RUSS
Old Dec 7, 2008 | 05:18 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
more likely than not its the brake flex line . they collapse internally , blocking pressure & not releasing press. . my advice would be to change all of your (3) rubber flex lines . good luck .
Old Oct 29, 2011 | 09:52 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
I currently am having the same problem. Can it cause my bearings to go bad? cause there is a loud buzzing/grinding coming from my passenger side wheel.
dbrochard
Sep 19, 2015 08:13 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
