Brake swap BW -> GM
Old Dec 8, 2008 | 03:19 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Brake swap BW -> GM
So i have broken BW 2,77 (9 bold) rearend with disc brakes, now my question is it possible to put those brakes to standard GM rearend (10 bolt) ?? is it plug&play or will i need to make some custome parts to fit it??
Old Dec 8, 2008 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake swap BW -> GM
The axle flanges have a different bolt pattern. With 10-bolt backing plates, you should be good to go. Check the following link for another idea:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Old Dec 8, 2008 | 07:27 AM
WASyL's Avatar
thanks for info
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
