BW 9 bolt picture help please
Old Jan 22, 2009 | 09:38 PM
sittincamaro's Avatar
Engine: IVTEC 2.4L aka SBC
Transmission: auto
does anyone have some pictures of the brake set up on the 9 bolt bog warner rear with cast iron calipers. im looking for a guide to bend my lines, and install the calipers (there was no brake on the rear). i tried searching but i couldnt find any pictures with the stock iron calipers. thanks
Old Jan 22, 2009 | 09:47 PM
Transmission: auto
Re: BW 9 bolt picture help please
the rear came out of a 86 z28
Old Jan 22, 2009 | 09:49 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
if you can wait til the weekend i can help you out.
Old Jan 22, 2009 | 10:06 PM
Transmission: auto
sure ill take what i can get. im mostly concerned with the rubber lines to the calipers. do you know if they are rubber lines or does the hard line do straightto the caliper?
Old Jan 22, 2009 | 10:11 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
i want to say rubber, but i wont know for sure til i crawl under.
Old Jan 23, 2009 | 02:06 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Heres some pics. https://www.thirdgen.org/forums/body...-up-start.html
i think stock theres only 1 rubber line on the rear end it self and one that is coming off the chassis of the car to the rear end. i bought stainless steel lines i might go back to rubber. but if you want you can run hard lines on the rear end it self since its a solid axle. you will still need a flexible line coming off the chassis to the rear end. . .
btw theres a few company's that make pre-bent hard lines for the 9-bolt with iron calipers. . .
Last edited by FueledSoul; Jan 23, 2009 at 02:07 AM. Reason: Automerged Doublepost
Old Jan 23, 2009 | 10:15 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
ive got steel bent line on the drivers side and a rubber line on the pass. send me your email addy, and ill send the pics to you.
just seen these:
http://www.thirdgen.org/techboard/en...s-braided.html
Old Jan 25, 2009 | 12:12 AM
FueledSoul's Avatar
so you got this all figured out now dude?
Old Jan 25, 2009 | 12:19 AM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
there is a rubber line between the hard line at frame to distribution block on rear end. then a rubber line going to each caliper. i replaced mine with stainless steel braided lines for 4 wheel discs. comes with all 5 lines.
Old Jan 26, 2009 | 09:17 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
This is not the same design as the '88 and prior rear disc setups, they only had one flex line on one side.
See if this helps. I'm pretty sure the flex line is on the passenger side but it's hard to see:
Frozer!!!
Jan 19, 2024 04:55 PM
chubsworth
Aug 26, 2015 02:34 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Elliswon
Aug 10, 2015 12:33 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
