Happy to still be with you
Old Jan 24, 2009 | 08:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You know how they say "Ignorance is bliss"? Well, I was pretty blissful.
The Berlinetta #2 that I picked up for the LS1/T56 swap had a lot of things replaced on it, including the front brakes. I had the A-arms down to replace the engine mounts, springs, and install poly bushings, and in the process disconnected the brake hoses to ease the task. The first thing I noticed was the right side hose had not been replaced and needed to be, so I found one to put on when the rest of the job was finished.
The left hose had been replaced, as had the hard line with a piece of universal brake line. After I separated the two, I was doing the spring and bushing thing when I noticed something funny about the hard line - as you can see in the first picture.
When I replaced the right side hose, I discovered both copper washers were under the bolt head instead of one on each side of the banjo fitting. Going back to the left side, discovered that's the way it had been done as well.
At least they were consistent.
I drove the car from the Bay Area to the Denver area, over the mountains, plus more after getting home for a total of 3000 miles or so before pulling it into the garage for the swap. It's a wonder I'm still with you.
Attached Thumbnails Happy to still be with you-left-brake-line.jpg   Happy to still be with you-right-caliper-copper-washers.jpg   Happy to still be with you-left-caliper-hose-nut.jpg
Old Jan 25, 2009 | 12:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Happy to still be with you
wow that could have been bad! Its good to still have you here!
Old Jan 25, 2009 | 12:45 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
And it's just as likely a 'brake' shop did it as some mis-guided previous owner.
Old Jan 25, 2009 | 01:04 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
wow mountain driving with that
I'm no automotive genius, but even I know that was dangerous. Had an angel for a co-pilot I say.
Old Jan 25, 2009 | 01:40 PM
five7kid's Avatar
I never met the previous owner, as the car was a donation purchase. The guy who handled the sale said the PO had taken it on as a retirement project, and then for some reason gave up on it (health, I would presume). The number of new parts is extensive (such as the front calipers), I doubt it was done by a shop. But, could have been.
This is just one in a long list of stories that would back that up.
Rather than hassle trying to find a double flare tool (don't have one myself), I'm just going to replace the line. I'm putting in a line lock and will have to reroute it, anyway.
Old Jan 27, 2009 | 03:54 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It merely would might have leaked.
Don’t get too nervous.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights on in the day time!
Old Jan 27, 2009 | 07:37 PM
five7kid's Avatar
Yeah, hydraulic system leaks usually aren't a problem. . .
Old Jan 27, 2009 | 08:14 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Dude, better buy a lottery tickey
Old Jan 27, 2009 | 10:35 PM
five7kid's Avatar
I feel a little better now - the left side had a washer on both sides, just too many of them.
Actually, I feel a lot better with the way the system is plumbed now. New hose, new hard line, line lock.
InfernalVortex
Apr 20, 2021 11:31 AM
tyeo098
Nov 30, 2015 06:27 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
buckeyecelt
Sep 24, 2015 05:50 AM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
