Brake Porportioning valve.
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
I just picked up my 4th gen rear today and i could not find a Porportioning valve on the car, the lines went from the master cylinder to the ABS module (no Porportioning valve)..... do i need the Porportioning valve? My car is a 1989 Camaro with a drum rear stock. I got rid of the rear but i'm wondering what cars i can use the Brake Porportioning valve off of or if i need one. Thanks
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
Re: Brake Porportioning valve.
There Is Not A Standalone Proportioning Valve On 4th Gen's.
You Can Use Your Stock One. It Will Brake Ok, You Can Buy One A Aftermarket One https://www.thirdgen.org/propvalve Or Since Yours is a 89' Find out If Your Proportioning Valve Is The 1st Design M1.0 84' To Early 89" Or 2nd Design M1.5 Late 89' To 92'
dbrochard
Sep 19, 2015 08:13 PM
