brake lights only work sometimes(90 camaro)
Old Feb 7, 2009 | 10:46 PM
a1990camaro's Avatar
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
can sum 1 tell me how to find the brake light switch on a 90 camaro rs. sum 1 told me that might be the problem,my brake lights only seem to work sometimes.the tail lights come on except the third tail brake light and the dash or gauge lights dont come on either...
Old Feb 7, 2009 | 11:06 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: brake lights only work sometimes(90 camaro)
Dash lights - have you checked the fuse?
Brake lights - could it be a bad ground somewhere?
Old Feb 7, 2009 | 11:28 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
The gauge lights are controlled by the dimmer switch.
Old Feb 8, 2009 | 05:47 PM
camaros dont have dimmer switches THIS POST IS FOR A CAMARO NOT A STUPID FIREBEIRD
Old Feb 8, 2009 | 06:03 PM
BladeQuarter's Avatar
Car: 1989 Chevy Camaro RS
Engine: Proud V6 Owner
Transmission: 5 Speed
Axle/Gears: unk.
Calm down bud, Yelling at someone isn't gonna get your question answered. more than likely youll just get ignored for it.
As killert said, check the fuses and make sure there isn't a ground fault happening somewhere
Old Feb 8, 2009 | 06:45 PM
dont tell me to calm damn you stupid bit*h this is my post. he should read i have a camaro so his info would hurt me more than help....plus i hate stupid firebirds they look like a cheap swap-meet knock off of the camaro.... the back lights look like crap and the stock rims they came with are horrible. so FUC* YOU BladeQuarter and your cheap *** v-6 step it up to a v-8 you puss*
Old Feb 8, 2009 | 07:19 PM
Axle/Gears: unk.
If I wanted a gas hog I would have bought one, but I didn't. Also I wasn't attacking you, I was trying to be nice, and also trying to help. But if you want to attack, Fine. I will not follow that ignorant path.
Also if you have a little common sence and $20 go to the autoparts store and gat a Haynes manual or Chiltons Manual. The Stop light switch is on the Brake pedal(Front side)and it clips in.
Also a camaro does have a dimmer...ITS BUILT INTO THE HEADLIGHT SWITCH...So his info was somewhat helpfull to others
Your welcome
Old Feb 8, 2009 | 11:00 PM
i do have common sense you idiot why pay 20 when i can get the answer here? makes sense to me now stay the hell off my message post you v-6 puss*
Old Feb 8, 2009 | 11:02 PM
Axle/Gears: unk.
reported for breaking Forum rules
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
