92 pbr disk in 86 drum car. (line question)
Old Feb 16, 2009 | 09:31 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i am swapping a '92 posi 3.42 pbr disk rear (yay! i found one!) into my '86 that had a 2.73 drum pegleg. i will be using the stock front calipers and rotors for now
my question concerns the brake lines. i am looking at earls or g-stop lines (hoses) and wondered if the threads and lengths of the hoses are the same for either style?
also, i know i will need new rear lines and i already have the correct conversion valve, will the hard lines from the conversion valve to the master cylinder swap or is there a thread difference there?
i also know i will need a new parking brake line.
thank's in advance for your replies!
Eric B
Old Feb 16, 2009 | 09:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 pbr disk in 86 drum car. (line question)
Originally Posted by SLEEPER 86
my question concerns the brake lines. i am looking at earls or g-stop lines (hoses) and wondered if the threads and lengths of the hoses are the same for either style? also, i know i will need new rear lines and i already have the correct conversion valve, will the hard lines from the conversion valve to the master cylinder swap or is there a thread difference there?
There is no thread difference (if you have the correct proportioning valve), front or rear. The proportioning valve will bolt up. Purchase Earl's lines, which you can see in the following link:
http://www.spohn.net/shop/1982-1992-...l-Brake-Lines/
The set that you'll need is Earls-4D-8992-F
JamesC
Old Feb 16, 2009 | 09:54 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
thank's for the super fast reply James!
much appreciated!
E
Old Feb 16, 2009 | 12:43 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
i noticed on steve spohn's site that he sells a master cylinder for 1984/1988 4 wheel disk cars, is there a big difference in the standard disk/drum master cylinders and the 4 wheel disk one? could the different ratios pop a seal somewhere?
Old Feb 16, 2009 | 12:51 PM
JamesC's Avatar
Nothing to be concerned about (check the first post in the following link for an eye opener):
https://www.thirdgen.org/forums/susp...fferences.html
JameSC
Old Feb 17, 2009 | 07:06 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
very interesting,
i was always a fan of non power brakes anyway. the heavier pedal feel is actually a plus for me.
thank's again James!
E
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
