Brakes squeaking -HELP!!!!
Old Mar 15, 2009 | 12:14 AM
murrayfan97m's Avatar
i have a 2000 trans am ws6. has 53k on it. i bought it about a year ago and not long after i bought it the brakes started squeaking all the time. had a few places look at it and said maybe just need new pads, so i tried that, didn't work. I just had a new place look at it and said it's the rear rotors and they need replaced. SO i got brand new rear rotors ..brand new pads for the rear rotors andd front, and the brakes STILLL squeak. i've only had the new rotors on 2 days. DO the new rotors just need time to set in? My brakes squeak BADLY around 80% of the time. It's usually when i tap them or push them in half way...if i push hard and all the way down they dont' squeak but at all other times they do, it's sooo annoying when i'm driving through parking lots and even down the road and always hear it!!! PLZ help!
Old Mar 15, 2009 | 12:23 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Brakes squeaking -HELP!!!!
It could be anything. First thing I would check is maybe your wheel bearings. But also when you changed brakes did you use brake grease on contact places? That's the only thing I can think of other than the pads are bad.
Old Mar 15, 2009 | 12:25 AM
i'm pretty sure they used grease. what color is it usually? these guys seem like they know what they are doing and they did a header and y pipe install for me and did a great job!! my brake problem just wont' go away!!
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
