Which Calipers Do I Have?
Old Mar 11, 2009 | 08:20 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Im in the middle of a disc swap and I have a few questions
I got the rear from a local member but he did not know anything about it, how can I tell if it has the performance options?
The calipers I got are off a 88 formula and they need to be rebuilt how can I tell which kit to get? Same with the pads there is a performance and not performance.
Old Mar 11, 2009 | 08:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Which Calipers Do I Have?
There's some brake info in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 15, 2009 | 01:16 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
If you're rebuilding the existing equipment, find a competent
counter-man at one of the better parts houses. And O'reilly's, NAPA,
Car-Quest, will have a better selection of upgrades than the likes of
Auto-Zone, Pep-Boys, etc. (And beware, there will still be chuckle-heads
at the better houses.) Then take your existing parts along. "I want to
rebuild/replace these." The counter-man competency can help you
determine the performance options most suitable for you.
Good luck,
kk
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
