1984 firebird brake replacement
Old Mar 17, 2009 | 10:10 PM
79_T/A_guy's Avatar
Car: 1978 Trans am
Engine: 6.6 400
Transmission: TH350
Axle/Gears: Good question
hi, im looking to completely redo my entire brake "system" in my 1984 firebird.
i plan on replacing everything, and was not sure what all would be the best bang for the buck. i have a stock 5.0L 305 and dont need anything insane, but i want to redo it all. i am having a hard time finding alot of parts and i have the stock 15th anniversary rims on so anyways any and all help would be appreciated.
i really dont know all the parts i would need and what brands to get and which to stay away from.
this will be my first brake job, however i have a friend coming intown in about a month who is a mechanic, so he said he would be more than happy to help but i have a hard time talking to him(he is hard to reach) anyways id like to have all the parts here when he gets here so we can get right into.
thanks
-alex
Old Mar 18, 2009 | 11:41 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: 1984 firebird brake replacement
How much are you looking to spend?
For replacement of the entire stock brakes, here's what you want:
For the fronts:
2 Front Calipers
2 Front rotors (Or you can have yours turned if you want, you'll have to price it out!)
1 set of front pads
2 front rubber brake lines
Some brake fluid
Inner/Outer wheel bearings, grease seal
Disc brake axle/bearing grease
For the rears:
Do you have drums or disk?
Old Mar 18, 2009 | 11:50 AM
79_T/A_guy's Avatar
Car: 1978 Trans am
Engine: 6.6 400
Transmission: TH350
for the rear i have disks, and id like to keep it as cheap as possible
Old Mar 19, 2009 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
2 rear calipers
2 rear rotors
Rear pads (1 set for each side)
2 rear rubber brake lines (line to body, line to pass side caliper)
Turning the rotors is certainly an option, but I'd suggest new--everything else will be, so why not?
Old Mar 19, 2009 | 12:57 PM
79_T/A_guy's Avatar
Car: 1978 Trans am
Engine: 6.6 400
Transmission: TH350
Originally Posted by JamesC
2 rear calipers
2 rear rotors
ok thank you very much, i was considering doing braided lines instead of rubber ones, and are there any brands i should look at over others? id rather not spend 2K on this but most things in life dont come cheap so i will if need be.
Old Mar 19, 2009 | 01:12 PM
JamesC's Avatar
Check these:
http://www.spohn.net/shop/1982-1992-...sc-Brakes.html
JamesC
Old Mar 19, 2009 | 01:17 PM
79_T/A_guy's Avatar
Car: 1978 Trans am
Engine: 6.6 400
Transmission: TH350
wow i just book marked that site, it literally has everything i need.
thanks a ton
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
