PBR Developing a Rust Ring
Old Mar 26, 2009 | 09:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Last summer I replaced the axles, bearings, and seals. While I was at it, I swapped in new rotors (AC Delco) and pads (Hawks), front and rear. Formerly, the pads swept the rotor faces clean. Currently, the driver's side rear is developing a light rust ring where apparently the pad isn't touching and should, both on the inside/outside faces toward the hub. Thinking the problem was mechanical, I removed the caliper and made sure that the slide pins were in good shape and thoroughly lubed. No difference. For the above to happen, the pads would have to be canted somewhat like this / \ on either side of the rotor. If all is good mechanically, could the rotor itself be the problem, and instead of being parallel, be shaped more like this \ /? Maybe that's as clear as mud. Anything else to consider?
JamesC
Old Mar 26, 2009 | 11:02 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: PBR Developing a Rust Ring
Dude, u-da-man for brakes on this board, so this is a test right?
Short of taking the rotors to a good shop for a true-up cut,
can you measure the components with good calipers?
Eventually the pads will wear down to contour with the rotors,
but thats the lazy way out, right?
kk
Old Mar 27, 2009 | 12:04 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Pictures would help a ton....
Personally I think I might take it up to speed and stand hard panic style on the brakes a couple times just to see what happens, mist em' down with water, let em rust over, then do it again.
Now sure what that would accomplish...but that's just me.
Old Mar 27, 2009 | 07:03 AM
JamesC's Avatar
I think you have me confused with Ed Miller .
JamesC
Old Mar 27, 2009 | 07:10 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Cast iron saginaw rears, right? You have to set it pretty close when installing so that the emergency brake can keep it adjusted tight.
Have you installed the recall kit?
Old Mar 27, 2009 | 07:13 AM
JamesC's Avatar
No, I did a PBR conversion several years ago. I should have noted that in my original post.
JamesC
Old Mar 27, 2009 | 07:28 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Im still having the same problem with my rear calipers James. The pads are only cleaning the outside edge. The more i drive it however the better it gets. And i know that the calipers are not seized up so i think its just a matter of everything breaking in with eachother..or at least i hope it is.
Old Mar 27, 2009 | 07:38 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Well, what will happen is that your pad will wear heavily where it's touching first, then over time it will begin to form itself to the angle of the rotor, assuming the rotor is what's not parallel. So yea, over time it will get better looking, but nothing has actually been fixed, and you will get uneven wear on the pads that should be visible.
Old Mar 27, 2009 | 07:39 AM
JamesC's Avatar
If the issue is with the rotor and its tolerances, I'm annoyed--I purchased AC Delco because I thought the company would offer a better product than other brands. That said, the ring isn't terrible and I suggest it'll wear out, but unfortunately I'm **** enough to be irritated.
JamesC
Old Mar 27, 2009 | 07:43 AM
subroc's Avatar
Engine: 355 TPI
Yea im **** too about it and this pissed me off for a bit. But granted i have barely 300 miles on all the new brake parts and now they are starting to wear in to eachother pretty well. You would think though that AC delcos would just wear evenely to begin with.
Fireslash
Apr 11, 2016 06:43 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
tcflint
Sep 27, 2015 05:58 PM
