LS1 front brakes on spindle?
Old Apr 1, 2009 | 12:13 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Why not mount the caliper on the spindle? Is there any real need for the adapter? Looking at it I don't see why you couldn't just drill a couple holes in the spindle and use some spacers to get it in position. This might be a good way to get enough clearance (with 12" rotors) to fit them under 15" wheels.
Old Apr 1, 2009 | 11:18 PM
bl85c's Avatar
Car: '85 maro
Re: LS1 front brakes on spindle?
Anyone tried it?
Old Apr 2, 2009 | 10:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For the 1LE set-up, at least, you have to drill/tap the spindle. The bridge between those two holes, however, is too far apart to mount the carrier--which is mounted to the adapter, not the caliper.
Old Apr 2, 2009 | 11:56 AM
bl85c's Avatar
Car: '85 maro
Ya, I meant the abutment bracket on the spindle. The LS1 bracket is 128mm between mounting bolts, which can be mounted on the spindle. Major concern I have is parallelism with the new bolt holes.
Old Apr 9, 2009 | 12:09 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i tried searching for ls1 brakes on our cars and really got nothing. anyone can guide me?
Old Apr 9, 2009 | 12:53 AM
joeblow's Avatar
Car: 92 RS
Engine: LSX
Axle/Gears: 4.11
https://www.thirdgen.org/forums/faq-...s1-brakes.html
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
