Poor braking when first starting out
Old Apr 6, 2009 | 11:41 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
This is a 91RS with stock disc/drum brakes. When I first start out with the car after it has set for a few days it has little or no braking. Seem like the rear brakes do not work at all. After driving for a while braking improves, but still is not great.
I have replace the rear brake shoes, adjusted the rear brakes, and bleed the brake lines. No fluid leaks. I put the rear on jack stands and the rear brakes were unable to stop the wheels (either side) with the car idling in gear.
What do I try next. Master cylinder??? Prop Valve???
Old Apr 7, 2009 | 01:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BROKE BRAKE
Most likely you need new rear wheel cylinders.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Apr 7, 2009 | 01:15 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: BROKE BRAKE
there is a similar post going on right now...might have some good info for ya...here is link...
https://www.thirdgen.org/forums/brak...nyone-can.html
Old Apr 7, 2009 | 07:23 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: BROKE BRAKE
Yes, I had followed that other thread. Even though that is for rear disc, it has many similarities.
As for the wheel cylinders, I think it is a possibility, however find it unusual that both sides would start doing this at the same time. I guess that is why I was thinking more in line with something that would effect both sides.
Frozer!!!
Jan 19, 2024 04:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
