stock master cylinder to use manual brakes
Old Apr 13, 2009 | 02:55 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay so There was this guy i was talkig to, a knowledgeable man, said i could get by by just bypassing my power booster and just bolting up my master cylinder to an adapter plate. He also said bolt it up an inch higher and also bolt the the rod an inch higher on the pedal. this will give the proper leverage.
now what am i missing then? I mean i know the piston bore is much larger than the proper manual brake ms. but this is temporary for idk how long. id have to shorten the rod correct?
I looked up the bore size of a 85 blazer that has manual brakes and its pretty much the same bore size. Maybe they had a typo but there is a jimmy at my junkyard with manual brakes. Im prolly going to rob it, but if my ms works for now id be content to run this.
its a car that runs at the track and cruises on the street on the weekends
Old Apr 13, 2009 | 04:58 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
Re: stock master cylinder to use manual brakes
There are some on here that use S-10 manual master cylinders. You will need to check bore size on the factory mc.
Old Apr 13, 2009 | 07:50 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Stock iroc is 1.44
S10 is 1.25
Old Apr 18, 2009 | 09:35 PM
Pocket's Avatar
Car: 91 Trans Am
You will also have to fab a rod from the pedal to the master piston
On power brake cars it is part of the booster
Old Apr 18, 2009 | 09:44 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I have my pushrod connected 2" from the pivot on the pedal, which I believe was more like 2" higher than the stock location. I'd be sure to put the pushrod up quite high especially if you're looking to use a master with a larger than ideal bore. FWIW, I'm using a master cylinder for a 68 vette with manual brakes and it worked, but adding the LS1 rotors, calipers,... really made it much better.
Old Apr 19, 2009 | 07:47 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ya i just realized my 74 nova has manual brakes. so im just gonna rob it.
Old Apr 21, 2009 | 11:36 PM
rayar's Avatar
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
I just used the stock MC on my 83 Camaro and it works fine. Didn't even move the rod. Not much more pedal effort then with the booster. This is with a CP autocross car. I can still lock the brakes easily.
1992 Trans Am
May 10, 2023 07:19 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
