brake problems.
Old Apr 16, 2009 | 03:07 PM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
brake problems.
hey guys, so i was needing to redo my brakes (front and rear), because the rear brakes werent functioning, and thefront ones were taking a beating. im working on the rear ones, and the piston wouldnt go back into the caliper to get it back over the rotor with the new pads, so i took it apart like it says in the chiltons manual. taking the piston out of the caliper and there are springs and a screw-type mechanism inside the piston. there is no mention of this mechanism in the chiltons manual. so now i need to get the piston back in, but i dont have any clue where to get the tool to reinstall the piston. and when i look for new parts at rockauto, theres no parts to repair this screw-spring mechanism. whats up with my calipers?
note, the right rear piston was out pretty far and it wouldnt stay out when i kept my foot on the brake and it hardly moved, and the right left was in pretty much all of the way, and i still couldnt get the caliper with new pads over the rotor.
this car has had a ton of work from previos owners, so im really not sure whats up with anything on it.
this is for an 1987 IROC-z with 5.7
any help will be GREATLY appreciated. thanks guys.
Old Apr 16, 2009 | 04:50 PM
chava454's Avatar
Car: 91 camaro Z-28
Engine: 350 borla cat back MSD ignition
Axle/Gears: 2.23:1
Re: brake problems.
they sell the generic tool at any autoparts store its tricky to get it in but with the right tool it is posible it has to be twisted as it is pushed in i once hamerd one in before i know about the issue it worked fine but i wouldent sugest doing that just get the tool
Old Apr 17, 2009 | 02:35 PM
Car: '87 IROC-Z/28
Engine: 357 HSR
Re: brake problems.
all right, ill call up napa tomorrow and ask them. thanks.
MM2Robinson
Oct 1, 2017 09:16 AM
dbrochard
Sep 19, 2015 08:13 PM
Ranbo108
Sep 9, 2015 12:20 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
