Adjustable prop valve install questions, using stock combo valve.
Old May 5, 2009 | 01:47 AM
87350IROC's Avatar
Car: 87' IROC
Several years ago I installed a willwood adjustable prop valve. I installed it while retaining the stock combo valve. I just removed the stock prop valve plunger and spring, then installed the willwood below the stock combo valve.
I've seen a bunch of info on here that may indicate this is a bad idea. Although I've been driving with it like this for years with no issues.
With the plunger and spring removed doesn't the willwood see full pressure on the high side? Which is what we want. This has no effect on front brakes, right? The stock combo valve keeps the front and back brakes separate, right?
Thanks,
John
Old May 5, 2009 | 02:14 AM
87350IROC's Avatar
Car: 87' IROC
Re: Adjustable prop valve install questions, using stock combo valve.
here is my set up
Old Aug 19, 2009 | 09:57 PM
dbp91z28's Avatar
I am about to do the same thing in a '91 Z28. Added 12 bolt & LS1 brakes. Even with LSI valve installed and also a 1LE PV installed, still not enough bias to the rear wheels. It seams obvious to take out the valve, but just checking.
Old Feb 26, 2019 | 11:17 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Still would love to hear a definitive answer on these questions, anyone? J65 -vs- Drum. Is the only difference the plunger and the spring? Valve body identical? How do we know what is inside these valve bodies anyway? I'm assuming it is simply a tunnel for brake fluid to run thru, but do we know with out a doubt diameters and lengths of these tunnels are the same? And one other question, does the front brake have a plunger/spring system similar to rear? It looks different??
Old Feb 26, 2019 | 07:00 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I did something similar just last week. There has been some good talk recently on the brake board about the combination valves and such. read a few of the recent posts in the brake board for some good info
here is my (untested) setup
https://www.thirdgen.org/forums/brak...wood-line.html
i think it should work
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
