Master cylinder reservoir bubbling after bleeding ?
Old May 11, 2009 | 05:52 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Hi guys,
I've just finished replacing the leaky rear caliper on my 84 T/A HO. I've bled the rear brakes only to remove the air, not the fluid. They're working fine, they hold the rear wheels firmly, same for the e-brake (though I need to adjust the cable).
But now when I push the pedal, it's spongy half way and then it's strong as it should. Also, I can see bubbles in the M.C rear reservoir.
I was told I shouldn't have pushed the pedal all the way down when bleeding the brakes. Does that mean the M.C is toast ?
Thanks, Bye
Old May 13, 2009 | 10:38 AM
50bmgshooter's Avatar
Re: Master cylinder reservoir bubbling after bleeding ?
sounds like air in the master
did you let the reservoir empty? if so bleed the master then bleed the lines back out
Old May 13, 2009 | 10:45 AM
Stephen's Avatar
Car: 87 GTA
Sounds like whoever was pumping the brakes, might have lifted their foot a bit, before the bleeder was closed, & sucked air in.
Or worn threads somewhere/the bleeders themselves are bad, allowing air to get sucked in.
Old May 14, 2009 | 11:48 AM
No, as I said, I bled only to remove the air in the system. I haven't replaced all the fluid.
Old May 17, 2009 | 10:36 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
There is air in the line.
Bleed it again.
Old May 17, 2009 | 11:38 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
when u bleed your brakes you suppose to make sure u got plenty of fluid in the front and rear resevoir and then keep doin the procedure until u get nuthin but fluid a couple of times.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
