rear disc bolt pattern
Old May 22, 2009 | 07:28 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i have a set of explorer rear disc brakes for a 9" and of course it has a ford bolt pattern. well i got a really good deal on a set of wheels that have a chevy bolt pattern. question is does anyone know a chevy rotor that will fit with the rest of the ford stuff or if not has anyone ever had rotors drilled for a different bolt pattern. moser will do it but i dont really want to mess with shipping and stuff.
Old May 22, 2009 | 07:37 PM
Stephen's Avatar
Car: 87 GTA
Re: rear disc bolt pattern
Any good CNC machining shop could redrill a new pattern for you.
Shouldn't be hard at all, to find one willing to do it for you.
It would just still be up to you to get the new studs pressed in, but that would easy to get done, or do at home.
Old May 22, 2009 | 07:41 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
new studs pressed in? im guessing you mean on the axles but i havent ordered them yet and when i do ill just get them with the chevy pattern.
Old May 22, 2009 | 07:45 PM
Stephen's Avatar
Car: 87 GTA
Yeah. I just mentioned it in case you were going to need that done too.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
sailtexas186548
Jan 19, 2016 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
