rear drums: uneven braking problems
Old Jun 5, 2009 | 10:11 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Hi guys,
i just had my 89 formula inspected and they found my rear brakes to be quite uneven, values below are all in kilonewton.
driver side | pass side
foot brake:
0.7kN | 2.5kN
e-brake:
0.6kN | 2.0kN
i had the same problem last year and i put a new wheel cylinder in the driver's side drum and new pads on both sides which fixed it, that's maybe 2k miles ago. but lately i've noticed that at low speeds and low brake pedal pressure the right rear tire sometimes blocks, obviously because the left one doesn't brake a whole lot at all...
the lines seem to be okay and the distributor T-fitting rarely fails, i suppose. oh and yes i have read the brake 101 sticky any other ideas? maybe the cylinder is sticking or the return spring came loose or something.. btw i don't have any (external..) leaks.
thanks for any comments and hints guys
i wont drive the car now as i wont have time to look at this issue until next week, so i'm gathering some ideas.
Old Feb 2, 2014 | 12:54 PM
Camatruder's Avatar
Car: 88 Camaro V6
Re: rear drums: uneven braking problems
Hi Ownor, old thread i know, but i have a similar problem. How did you fix it?
Old Feb 3, 2014 | 03:04 AM
ownor's Avatar
Engine: LS1 / L03
hey man,
frankly i switched over to disc brakes (3.27 9bolt rear end) some months after that.. so no advice i can really give, sorry. since mine now has the earlier J65 Delco-Moraine calipers however i'm having problems getting the ebrake working and adjusted -.-
best bet imho is to get the 89-up pbrs and be done with it (or so i'd think).
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
