swapping rearends, aluminum drum to pbr disc.
Old Jun 14, 2009 | 09:59 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Im swapping my 87 aluminum drum(2.73) diff for a 89 pbr (3.42) diff. all the lines and ebrake cables are there except for the rubber line with the T fitting. Will my current rubber line work for the new rearend?
Old Jun 14, 2009 | 11:39 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: swapping rearends, aluminum drum to pbr disc.
Should. I did a similar swap and everything bolted right in place. I used the stock rubber line with T fitting and it went right on.
Old Jun 15, 2009 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Remember that you'll need to swap the proportioning valve for best braking performance. You'll also need to swap the drive and driven gears if you want the speedo to read correctly.
JamesC
Old Jun 15, 2009 | 07:00 AM
skinny z's Avatar
JamesC
I've been reading about the poor performing rear brakes (using the Delco Moraine calipers) and possible solutions.
Most of the info is in regards to the prop valve and suitable replacements or modifications.
The application on my current ride is the same as the above poster. I garnered a master cylinder and proportioning/combination valve from a donor disc brake car when I swapped in a disc brake rearend. The rear pads still appear new after tens of thousands of miles of use.
What is the definitive word on which prop valve to use?
Old Jun 15, 2009 | 07:18 AM
JamesC's Avatar
Where PBR's are concerned, GM offered valves (with different part numbers) for discs and drums, to provide the best performance for both those braking platforms, I'd guess--as cheap as GM is, logic says that the company wouldn't produce two valves when one was sufficient. For what it's worth, Ed Miller, Dan Burke, and AndyZ28, all advocate the 1LE valve.
JamesC
Old Jun 15, 2009 | 07:28 AM
skinny z's Avatar
Would that apply also to the iron Delco Moraine calipers ( that I understand are of a poor design to begin with )?
Old Jun 15, 2009 | 07:45 AM
JamesC's Avatar
Yes, different part numbers for the two applications. BTW, personally, I think Delco-Moraines get a bad rap on the board. I ran them for a number of years without issue. I swapped to PBR's, not out of necessity, but because I'm a foolish hobbyist who enjoys spending hard-earned loot and getting his hands dirty.
JamesC
Old Jun 15, 2009 | 07:53 AM
skinny z's Avatar
Thanks for that Mr. C.
I have my current drive (which will soon be relagated to winter beater status) that has the D/M calipers. Those I'll keep however getting them to actually work would be nice.
My current project will have the PBR's (and a Dana 44). I'm still in the process of aquiring the various bits and pieces.
As for the foolish hobbyist comment, I concur. I understand now why women like to go shopping for shoes! ( OK. Not all women.)
Old Jun 15, 2009 | 08:10 AM
JamesC's Avatar
You may find the following link interesting (Note Defect Involved):
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
Old Jun 15, 2009 | 08:16 AM
skinny z's Avatar
JamesC
More parts to buy!
Thanks again.
Old Jun 15, 2009 | 11:20 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Ive read the drum brake and aluminum caliper(PBR) prop valve is so close there is no need to change. The iron calipers are a different story in relation to the fluid needed but from what I understand there is no need for the added hassle of a prop. valve swap. Am I wrong?
Old Jun 15, 2009 | 12:58 PM
JamesC's Avatar
If you have a link to the above, I'd be interested to read it.
My opinion all along is why bother to upgrade to larger brakes if you don't maximize them with the proper valve. Is "close" or "ok" good enough? For me, because I'm **** in such matters, the answer is no. BTW, Ed Miller includes a disc valve in his PBR kit:
http://www.flynbye.com/catalog/i10.html
JamesC
Old Jun 15, 2009 | 05:27 PM
subroc's Avatar
Engine: 355 TPI
I went the other extreme when i swapped from drums to PBRs and just bit the bullet and put an adjustable prop in. It is a bit of a pain to do but well worth the end result.
Old Jun 15, 2009 | 05:37 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
JamesC
I looked for the thread I was speaking of, found many where a member said it worked but with no actual info, where a member measured pad wear after the swap and ended up with something like 65% wear on front and 35% wear on the rear which was measured after a long period of time using the OE drum prop.valve but I couldnt find it. Eitherway I do agree doing a job halfa## is never a good Idea, I may as well switch since the master is being replaced anyway.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
