need 3rd gen disc brake help.
Old Jun 25, 2009 | 10:11 AM
joes407's Avatar
Car: 92 Z-28
Engine: 5.7 cam, aluminum heads, tpi upgrad
Axle/Gears: 3:42
when i bought my 92 Z in 93 it had no emrgency brake cables. i never really worried about it since the car is automatic. i recently found out though that the e-brake is how you adjust the rear disc brakes. what i found is that im missing a pair of cables that go from the single cable that goes to the lever, to each rear caliper. problem is that gm discontinued these cables and there seems to be 3 styles. autozone shows 2 applications, a 56 inch and a 57 inch cable so i called gm and they said according to my vin # that neither of those are what my car is equipped with. of course since they are discontinued they couldnt read any other info such as style or length of the cable. just looking for any input here.
Old Jun 25, 2009 | 10:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: need 3rd gen disc brake help.
While the adjustment was true with the old Delco-Moraine calipers, 82-88, I don't believe the PBR's, 89-92, require it. Here's some info on the cables:
https://www.thirdgen.org/forums/brak...r-e-brake.html
JamesC
Old Jun 25, 2009 | 02:42 PM
joes407's Avatar
Car: 92 Z-28
Axle/Gears: 3:42
thanks. that helps some. i dont have the adjustable cable pictured in that thread so i guess im down to 2 choices.
Old Jun 25, 2009 | 09:14 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Get the longer cable, better more than not enough, if length is the only difference. Also, check online for prices after you find out what you need. Usually stores overcharge ya, try looking on summit or classic industries.
Old Jun 25, 2009 | 09:21 PM
joes407's Avatar
Car: 92 Z-28
Axle/Gears: 3:42
not worried about the price since the pair is only 20 bucks at autozone. why bother payin for shipping?
Old Jun 25, 2009 | 09:53 PM
Tpx's Avatar
Tpx
That's a good price, don't bother with shipping
Old Jun 30, 2009 | 09:28 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
A little off topic... Why would a 1 year old car not have emergency brake cables??
Old Jul 1, 2009 | 12:53 PM
joes407's Avatar
Car: 92 Z-28
Axle/Gears: 3:42
that is a good question. i believe the car was hit and possibly had the rear changed. i found bits of glass under the back seat like the hatch had been broken. possibly slid over a curb or something as i couldnt find any signs of repair or damages back there except the glass bits and no e brake cables
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
