Loud "Popping" type noise when breaking
Car: 1984 Chevy Camaro & 1988 Trans Am
Engine: H/C/I LS1 & 305 LB9
Transmission: T56 Magnum-F 2.66 & Stock T5
Axle/Gears: QP 9" TruTrac 3.70 & Stock 10bolt
Hey, I've noticed recently that when I break theres a loud popping noise.
It's especially noticeable when I'm going slow - then again it might just be the absence of driving noise.
If I really gently ease into the break it doesn't do it.
It is definitely rather loud.
I have a 9bolt posi rear end with discs - not the original 10bolt drums.
It sounds like it's coming from the rear but once again I can't be positive.
Thanks for any help.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Loud "Popping" type noise when breaking
check your caliber bolts, is it both side or one only, 1 or more bolts may be loose allowing the caliber to move and make a clunk sound
k I will, I'm actually not 100% sure now as I was doing it slowly next to a building yesterday to try to get a better idea but I really couldnt tell if it was front or back, I think I'll have someone get into my car and do it and I'll just try to find the sound.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Yup, sounds like caliper bolts. My brothers grand prix just had this happen, one came lose allowing the caliper to move .1" with the bolt still in but it was noticeable and is now fixed. Check them out.
Car: 1991 Chevrolet Camaro 25th Anniv.
Engine: 5.7L 350 TPI
I have the same problem mostly on the driver side. I noticed this right after I changed my brake pads. I get a small pop when slowing to a stop and a bigger one when braking hard. I will check the calipers hopefully this does fix the problem.
sjorgens
Oct 1, 2015 07:54 PM
