Brake pedal sinks after hard cornering?
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Alright, I've been noticing this recently, but I can't say for certain that this is a new issue. After I take a hard corner without using the brakes, later when I go to brake, the pedal sinks an inch further than normal before it builds pressure. After I hit the brakes once, they are fine. My master cylinder is a LS1 style, as are my rear brakes. Otherwise stock. Brake reservoir is plenty full Any ideas?
Car: '88 Iroc
Re: Brake pedal sinks after hard cornering?
No one else has this happen?
Car: check
Engine: check
Transmission: check
Pad knock back. Happens for several reasons. Deflection in the brake mounting points will do it. Deflection in the axle flange allowing the rotor to 'tip'. Along with too much real axle end play.
Check the caliper pins and guides and such. Allowing the caliper to freely float helps in this regard.
RBob.
RBob.
Car: '88 Iroc
Ahh that makes perfect sense! Thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
RBob.
RBob.
1992 Trans Am
May 10, 2023 07:19 PM
