caliber bolts keep loosening up
Old Aug 12, 2009 | 10:46 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
ever since upgrading to ls1 fronts the bolts that mount my ls1 bracket to my spindle keep coming loose. i used loc tite with no results, one bolt actually came off today, i will need to replace it but what can i use to keep the bolts from loosening. my car does vibrate alot because of the drop and suspension woes any special bolts or locking material to use,
Old Aug 12, 2009 | 11:18 PM
87350IROC's Avatar
Car: 87' IROC
Re: caliber bolts keep loosening up
Try safety wire, the perfect solution for a problem like this.
http://en.wikipedia.org/wiki/Safety_wire
Old Aug 13, 2009 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Interesting. With the bolt torqued to spec and with red Loc-tite, I've never experienced any problems with my 1LE set-up. 87's right though, little worry with safety wire.
JamesC
Old Aug 13, 2009 | 01:37 PM
87350IROC's Avatar
Car: 87' IROC
James, I seem to recall hearing other people having the same problem with the LS1 setup. Not sure why it would be LS1 specific though.
Old Aug 13, 2009 | 02:09 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Red threadlocker (Loctite) and sufficient cure time should do it but I do recommend the wiring, it's practically fail safe.
Ed
Old Aug 13, 2009 | 02:27 PM
godreject's Avatar
thanks exactly what i needed i'l try red loc tite for now until i find the safety wire. im not sure what causes this but i've retorqued my screws a few times and they eventually loosen up, thanks for the replies,
Old Aug 14, 2009 | 08:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The other thing is to be sure that both the bolt threads and the spindle threads are degreased and dry. Then apply the locktite (red, #271), torque to spec and allow to cure for at least one hour before driving the vehicle.
RBob.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
TBRays98
Sep 6, 2015 05:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
