noises from rear
Old Aug 17, 2009 | 09:26 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
noises from rear
I swapped axles from my 87 GTA 10-bolt drum to a 9-bolt disc PBR from an 89 GTA and I cant solve my rattling problem.
If I kick the tires I can hear the rotor rattling, taken both rear wheels and calipers off numerous times and I still cant figure it out.
Everything is tight except the rotors, like they have little slack, enough to bang around, Any ideas?
Old Aug 17, 2009 | 11:22 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: noises from rear
Are you sure you aren't hearing the slack in the axles from the c-clips? That's normal.
Old Aug 17, 2009 | 11:24 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Aren't you sure you hearing the slack in the c-clips? Sometimes they can make a little racket.
Old Aug 17, 2009 | 11:53 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
9-bolts don't have c-clips
Old Aug 21, 2009 | 06:49 AM
Chriznoznae1's Avatar
Car: 91 camaro z28
Engine: L98 350, Vortech heads, Lt4 cam
Axle/Gears: 9 bolt 3.27
I just did this swap myself and I was wondering if you replaced the portioning along with the rear end. I didn't replace the portioning valve and it seems to work fine but wonder if it would work better if I bought the 4 wheel disc non 1le portioning valve from hawks third gen
Old Aug 21, 2009 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. Different brake designs, different proportioning valves.
JamesC
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
