What prop valve do I need?
Old Sep 26, 2009 | 08:23 PM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
I am swapping a 9 bolt with discs for a 10 bolt that had drums. A friend has a proportioning valve but he isn't sure if it came out of a car with rear discs or not.
How can I tell the two apart? Is there a casting number I can go by in order to make sure I'm getting the correct prop valve?
The rear end I'm putting in is out of an 89 Pontiac. It's going into an 87 Camaro.
Thanks!
Old Sep 26, 2009 | 10:08 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: What prop valve do I need?
Differences are internal, nothing on the outside will verify which is which.
Ed
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
