keep drums or disks ?
Old Sep 22, 2009 | 07:20 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , this question may of been asked many times...but again...my 1985 camaro has a posi 10 bolt rear end with drums...all works fine and stops great & the parking brake is working and holds the car down a driveway...i even upgraded to aluminium drums...now i have always thought about putting in discs brakes at the rear ,,but i hear so many horror stories about 3rd gen's with rear discs brakes never working properly and etc...is it worth the trouble?...should i fix what's not broken?....or should i look into aftermarket rear brake conversion kits for big bucks ..?///thanks ...
Old Sep 22, 2009 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: keep drums or disks ?
a great upgrade for the drum rear is the 4th gen rear disc brakes. a 12" rotor and single piston caliper, you can get the calipers, brackets, backing plates and cables on ebay for under a hundred bux. Ebmiller sells a bracket to bolt to your rear to make this a complete bolt on deal, or there is a tech article on the homepage in the tech section on how to modify you existing axle flanges to make the new brakes work. I did this swap on my drum rear back when i still had it and it was quite easy.
check it out.
however, if the current brakes work, no point taking it apart right now. Maybe just research this ls1 rear brake upgrade in the meantime.
Old Sep 22, 2009 | 07:41 PM
mooch1's Avatar
Transmission: T5 WC
thanks, you say the 4th gen rear brakes?...how can i search on ebay for them ?..is there a name like delco-moriane brakes?..does this set up have an e-brake?
thanks
Old Sep 22, 2009 | 07:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ls1 rear brakes, 125$, but not a bad price really
http://cgi.ebay.com/ebaymotors/LS1-R...Q5fAccessories
Old Sep 22, 2009 | 07:50 PM
mooch1's Avatar
Transmission: T5 WC
thanks,,,is this a direct bolt on ?...do i need to cut or do anything major?...also the prop valve needs to be changed?..does this set up have an e-brake..thanks..
Old Sep 22, 2009 | 08:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you obviously didnt read the tech article i pointed you to.
you need to do some work to the rear axle flanges, which involves removing the axles from the rear, a little cutting, drilling 4 holes, and tweaking the brake lines a little. Nothing really hard if you have tools and some mechanical ability.
Or like i said, ebmiller sells a bracket that will bolt to your exsisting drum backing plate and then allow you to use the 4th gen brakles, check out his site, its http://www.flynbye.com/index.html
Old Sep 22, 2009 | 09:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Many of your questions will be answered in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Sep 30, 2009 | 09:02 PM
mooch1's Avatar
Transmission: T5 WC
i just a set of aluminium calipers e-brake cables with prop valve and discs from a 1989 trans am...i can use that wonder bracket from ed and bolt it on directly to my 10 bolt rear drum flange...i saw the article on how to install the bracket and brakes..seems easy...are these breaks going to work and stop better than my drums?...or am i just better leaving my drums?...the axles need to be removed to do this swap...that i'm not sure how to do.....thanks.
Old Oct 1, 2009 | 06:57 AM
JamesC's Avatar
Check the link I provide above.
JamesC
6speedIROC
16
Mar 15, 2023 08:33 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
dbrochard
Sep 25, 2015 04:56 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
