Peddle get hard but does not stop
Old Oct 9, 2009 | 11:20 PM
raptor700r4's Avatar
I read a lot of the posting and could not find my exact problem. I have a sb350 with a demon carb. When I try to power brake, it just pushes the front end. I have 4 wheel disc brakes. Please help
Old Oct 31, 2009 | 04:42 PM
chevyboy07 91's Avatar
Re: Peddle get hard but does not stop
have a look at the vaccum line from the manifold to booster. Sometimes the plastic fittings crack or the hose itself might be broken, etc
Old Nov 1, 2009 | 04:17 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
could be a problem with your metering valve not allowing enough pressure to be applied to the front.just my .02
Old Nov 14, 2009 | 08:59 PM
rayar's Avatar
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Maybe your rear tires have more traction then the front. I know my front tires will just slide when I try to do a brake stand with my car.
Old Nov 14, 2009 | 10:36 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
im no expert, bad rear calipers, what year car. rear calipers are not considered the best.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Breazlan
Sep 25, 2015 11:20 AM
Joniz
Sep 13, 2015 01:28 AM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
