'82-89 1LE/J65 Proportioning/Combination valve NEW
Old Oct 12, 2009 | 11:26 AM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I just put an 84 rear with disc brakes in my 89 Iroc. Now i need to buy a disc/disc proportioning valve. I found one at flynbye.com. Just wanted to make sure that is the right one before ordering.
Thanks,
Jason
Old Oct 12, 2009 | 11:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: '82-89 1LE/J65 Proportioning/Combination valve NEW
You'll note that the above is for swapping the 1LE/J65 (89-92 PBR's with alum calipers and 11.7" rotors) into an earlier car. An 84 would have standard Delco-Moraine iron calipers and 10.5" rotors. A valve from an 85-88 (some 84's may have SAE fittings) rear disc car might be a better choice. That said, hopefully your 89 has the first design valve fittings: M1.0 tube nut threads (for 1982 to early 1989 applications), which would allow you to easily use the 85-88 valve. The second design, late 1989, is different: M1.5 tube nut threads.
Or you might consider swapping in PBR's:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
More info that you might find useful in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Oct 12, 2009 | 12:32 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
does anyone make the prop valve that I need? I'm not planning on upgrading the brakes to PBR just yet.
Old Oct 12, 2009 | 12:42 PM
JamesC's Avatar
I found the following on RockAuto:
1986 CHEVROLET CAMARO 5.0L 305cid V8 4BBL (G) : Brake/Wheel Hub : Proportioning Valve Price Core Total
ACDELCO Part # 1722005 {#14089497}
VALVE,BRK COMB USED W/M1.0 TUBE NUT THREADS; w/4-WHL DISC BRK(J65); CODE NB
* Non-stock item--shipping delayed up to 5 business days
The part number is also good on GMPartsDirect, so your dealership probably has it as well.
JamesC
Old Oct 12, 2009 | 01:10 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
thanks for the help
Old Oct 17, 2009 | 09:25 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
What about an adjustable proportioning valve????? I was talking to a friend and he put one on his car from Wilwood. He said that it is cheaper and does just as good. Have any experience with these on our cars??
Old Oct 18, 2009 | 06:49 AM
JamesC's Avatar
If your car has the first design valve, the bolt-in would be simply. If not, then the Wilwood would be an option, though you might need to cut/flare lines. Sorry, I don't know much about the latter valve or its installation.
JamesC
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
