brake light wont go off/ no brakes on van wyck
Old Oct 16, 2009 | 12:34 PM
charlietransam's Avatar
Car: 1984 Trans am
Engine: V8
i was driving on the van wyck out hear in new york and when i press on the brake i had none. so the next day i bleed the brakes but my brake pedal is not as hard as its supposed to be. and the brake light wont go off. what should i do bleed the master cylinder, replace the master cylinder, or change the brake booster.
Old Oct 17, 2009 | 06:36 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Re: brake light wont go off/ no brakes on van wyck
Light is on due to what is called a pressure differential switch. In a nut shell you got a leak cuz the light is on and you don't have a hard pedal
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
