LS1 to LT1 rear brakes
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Here is the deal. I have LS1 rear brakes on my Moser 12 bolt. Now, i bought a set of Greg Weld comp lite wheels. They said they wont fir the LS brakes, but they will fir the LT rear brakes. My calipers are ground down, so i need to check but he said they still wont work.
Now, i have a set of backing plates from a BW 9 bolt and a GM 10 bolt with the old iron calipers, will these work with the LT1 calipers? Or do i just have to get those clunker iron pieces? Or is there a chance(i doubt it) that the LS1 backing plates will work with any other rear brake calipers?
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: LS1 to LT1 rear brakes
I think you still need the lt1 backing plate since the rotors are 11in or so.
That's what my 10 bolt has on it. I'm not sure the 9 bolt would be compatible.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is what i was thinking, i just hate the iton backing blocks for the LT stuff. My buddy used a set of PBR third gen backing plates i think, had to shave a bit off if i remember correct...
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I'm pretty sure based on what I've read on here that the 89-92 PBRs are the same as LT1 rear disks. My buddy has a 94 Z28 and his brakes look identical to the PBR rear setups I have so I think it true.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 9- and 10-bolt PBR backing plates have different bolt patterns, so they aren't interchangeable. Use the correct backing plates for your application and the 89-97 calipers will work.
Check posts 20 and 21 of the following link for pics of the 9- and 10-bolt plates:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Hey if you are gunna be gettin rid of those LS brakes shoot a pm my way I may be interested in them for the right price.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The 82-88 Delco-Moraine backing plates won't work with PBR's.
JamesC
JamesC
LOL
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I should be finding out tomorrow if i can use them with the wheels.
1992 Trans Am
Aug 8, 2015 08:16 PM
