Performance drum brakes
Old Dec 4, 2009 | 09:55 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
Is this possible? do they make like cross drilled drum brakes? or something performance for drums? it would be for low budget people that dont want to upgrade to disc
Old Dec 4, 2009 | 10:09 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Performance drum brakes
There is a company that makes a larger diameter drum & hardware kits but IDK if any for 3rd gen rears--
I forgot the comp name but I wil try to find them in 1 of my HotRod,CarCraft,or SuperChevy mags.
IIRC the drums are 11 in. but I will look for the mags in a few.
I'm sure someone has the correct answer you're looking for,but I will look.
{edit}
Can't find it--will let ya know if I do
Old Dec 6, 2009 | 05:20 PM
Car: '87 Camaro
Sorry-I can't find the ads! I can't remember the comp name either! Sorry I was no help!
Old Dec 6, 2009 | 07:11 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
These guys look like they may have the solution:
http://www.praisedynobrake.com/
No direct install kits, but I'm sure it wouldn't take much to get it to fit on our rear.
Old Dec 6, 2009 | 07:29 PM
Axle/Gears: stock
i think im gunna call them they probably have got that call before hopefully ill get results and ill get back here with them
Old Dec 6, 2009 | 07:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you realize you can pickup a complete set of 4th gen ls1 style rear discs for just over 100 bux on ebay most of the time and you can swap them over without a lot of hassle, handtools and a drill?
Throwing money at trying to upgrade drums is a waste. Honestly though, the drums in good working order work pretty well.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
