Will a fourth gen slave cylinder bolt right up?
Old Dec 5, 2009 | 05:14 PM
Jeromey Cummins's Avatar
Hey guys, im having a hard time getting a streight answer for this question. Im switching my 87 over to an LS (LQ4) set-up, with a T-56. Before i install the set up, i want to intall the slave cylinder just because it will be easier to get around the engine compartment............. anyway, will a fourth gen LS slave cylinder bolt right up to my third gen, or will i have to do any modifications?
Old Dec 5, 2009 | 05:30 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Will a fourth gen slave cylinder bolt right up?
Last edited by Al Hasse; Dec 5, 2009 at 05:32 PM. Reason: Misread for master cylender.
Old Dec 5, 2009 | 06:41 PM
Thanks anyway! Keep the info coming guys.
Old Dec 7, 2009 | 10:59 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
This is in the brake board, however the only slave I know of is in the clutch system. What are you talking about?
Old Dec 7, 2009 | 06:02 PM
Ok, sorry. Ive always known it to be the slave cylinder master cylinder. The piece that mounts to the firewall, has two hoses running to and from. One goes two the cup that holds fluid, the other to the tranny. Also goes through the firewall, and attaches to the clutch pedal. If you look it up on th web by that name, it comes up as that part! Thanks for the input
Old Dec 7, 2009 | 06:03 PM
So anyway, will a fourth gen bolt up in place of a third gen?
Old Dec 7, 2009 | 06:12 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You named two parts there. A slave cylinder. And a master cylinder. The master cylinder bolts to your firewall and connects to the reservoir with a line that goes down to the SLAVE cylinder.
So, if you're asking if a fourthgen clutch MASTER cylinder bolts directly up to a thirdgen firewall. Yes, it does.
The slave cylinder is going to be dependant on what transmission you have and what year it is.
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
