installing adjustable prop. valve ??
Old Dec 27, 2009 | 09:20 PM
superirocz's Avatar
I just got my willwood adjustable prop. valve. I did read the install in the tech area. That article is very old and was hoping there was some updated fittings I could buy instead of buying flare kits and fighting with the lines. My car is a 89 iroc-z with factory discs on all 4 now with C5 brakes up front and a hydraboost system. The willwood valve has 1/8-27 NPT to 3/8-24 inverted flair fittings that thread in. I was also going to gut the factory prop. valve and just use it as a t-fitting.
The reason for install is my car locks the front brakes up long before the rear brakes do much work.
Frozer!!!
Jan 19, 2024 04:55 PM
dcbsracing007
Aug 18, 2015 07:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
