C5 Z06 brake upgrade, PN's, prices, links
Car: 2005 Audi A4 Avant
Engine: 1.8T
I have an Excel spread sheet with part numbers, the best prices I could find and links to the website of the vendor/source. I can't upload it because it's not a valid file format for upload. The list includes, calipers, rotors, pads, abutment brackets, bolts, flex lines, spindles, hubs, etc. Email me at anthony.lenhardt@yahoo.com if you'd like me to send it to you. It's less than $1900, not including shipping and handling charges.
Lenny
Lenny Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: C5 Z06 brake upgrade, PN's, prices, links
1900bux? that outrageous for a c5 upgrade, even for a c6 upgrade. It is nice of you to put the spreadsheet with prices and numbers together for the people here!
Engine: 1.8T
It is expensive compared to other brake upgrades, that's for sure. BUT replacement pads and rotors for this conversion, ultimately, will be easier to find years down the road since the Corvette is a regular production vehicle and their popularity will keep factories pumping out replacement parts for years to come. I'm not so confident about the other expensive, exotic upgrades that are available. If that company you bought your parts from goes bust, looks like you'll be performing another brake conversion.
A 1LE conversion would be much cheaper. I'm not a brake system expert, but spending hundreds of dollars to upgrade your 60's technology to 80's technology doesn't make much sense to me. Especially since it's ALREADY difficult to find 1LE parts. Years down the road, how expensive will it be to maintain that 80's technology?
Also, this list I have put together includes probably every nut and bolt you will need.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Lenny
LennyRaybestos loaded calipers with pads and abutments
part# RC11142QS $131.99
RC11141QS $131.99
rotors # 56701R 30.99
56700R 30.99
2 new front hoses, stock 3rd gen #15.00
new wheel bearings & seals $40.00
adapter brackets $75.00
hose to caliper bolts GM $12.00
grand total $467.96
I think a competent machine shop could do the required work in about 3 hours. around here that would be about $200to $275. Hope I didn't step on any toes, just trying to inform, Dean
Engine: LS6
ebmiller has the C5 front kit for $950. It's a bolt on, for those of you that don't wan't to or can't do it yourself. Thats a fair price for the parts and labor required. Dean
Engine: 1.8T
I guess I wasn't specific enough. This price is for front AND REAR C5 Z06 brakes. The price I mentioned includes all these parts:
12455799 - Caliper Abutment x 2 = $75.46
12530703 - Caliper Abutment Boot x 4 = $15.80
12530697 - Caliper Abutment Pins x 4 = $20.00
11570052 - C5 Caliper Banjo Bolt x 4 = $22.52
88895128 - Caliper x 1 +
88895129 - Caliper x 1 +
88895130 - Caliper x 1 +
88895131 - Caliper x 1 +
88926731 - Rotor x 1 +
88926732 - Rotor x 1 +
88926733 - Rotor x 1 +
88926734 - Rotor x 1 +
88909667 - Front Pads x 1 +
88909668 - Rear Pads x 1 = $750.00
39685 - Abutment to Bracket Bolts M14-2.0x35mm x 4 = $5.28
3GC5ASSY - Complete Spindle Assy, C5 Conversion x 1 = $475.00
C5RrConv10Kit - Complete Rear Kit, C5 Conversion, GM 10/12 Bolt x 1 = $350.00
RearLineKit - Rear axle and braided flex line kit x 1 = $100.00
PPB-CHCAM8292 - Stainless Steel Brake Hoses (1LE) x 1 = $54.75
Engine: 1.8T
Engine: LS6
Fronts are the same. I can't tell you about the rears. If is a third gen Camaro or Bird you want to swap to, I would consider the LS1 setup. Almost a bolt on, and you can still have a working parking brake. I don't know if anyone has this worked out on the C5 rears. Hope this helps, Dean
1992rs/ss
Jan 31, 2025 05:10 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
