Problem with the system. need help
Car: Trans Am "GTA"
The brake light turned on, & the pedal got soft. It goes in halfway before they start to grip, & I have to press really hard for the car to stay still.
There is no leak, & the fluyd level is normal.
Im thinking is the master cilinder, but what do I know?
I want to fix it Myself, but need to be shure what the problem is.
How to fix it, & how to upgrade it while Im at it.
I have 1LE rotors & calipers all around, & stainles steel lines.
thanks for the help
thanks for the help
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Problem with the system. need help
check for a vacuum leak in the system. At the check valve on the booster and the lines all the way to the throttle body.
with out the proper vacuum, the pedal will get really hard and you will have poor braking. Pulled my hair out for a long time trying to figure out my braking issues and it turned out to be a vacuum leak in the side of a piece of hose.
so ideally, remove and replace the hose form the throttle body to the check valve and put a new piece on and see what happens. If it doesnt help, check to see of the check valve at the boosted holds vaccum
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pressure Differential Switch? If so, it's alerting you to a leak in one of the brake circuits.
http://auto.howstuffworks.com/auto-p...ter-brake2.htm
JamesC
JamesC
Car: 86 Pontiac Firebird
Engine: 2.8 liter V6
Axle/Gears: 10 Bolt 2:73
hey alexcoqui, i kinda hav the same prob as you. i left state for lik 3 days,car parked on hill facing bottom. came bak home,brake light on and i hav no bak brakes. b4 i left state,my bak brakes worked,but my parking brake only worked in reverse. now i hav no bak brakes but my parking brake works forward and bakward. soooo im kinda interested in seeing wat ppl say bout wats goin on with your car. i hope our car problems arnt a pain in butt.
JamesC
