So much conflicting information ! I just need a good , cheap setup.
Old Mar 9, 2010 | 12:01 AM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
First off I have a 87 Iroc , 4 wheel disks. Basically I have no pedal in the car. Brakes work but the pedal is just not there , goes to the floor. The car has sat for 10 years so I can care less what is causing the problem. Basically I am redoing everything because it is well, needed. Calipers , rotors , rubber hoses , master cylinder, etc.
Now my question is this , what is a very low cost (stock parts from other cars, parts at NAPA) brake setup that I can bolt up to my Iroc. Now I know there will not be a whole lot of differance from stock but any improvement is better then nothing. Its not a road track or drag car , just a Saturday night cruiser that needs to stop at the red lights.
Some have said LS1 car brakes , others have said C5 brakes, others have said they all suck . I can not find any consistant info on anything. And yes I have searched . Have searched here among other sites aswell. Hopefully there is at least 1 person out there that can help. I need to buy these parts asap so any help would be great . Or else I will be staying with stock.
Old Mar 9, 2010 | 12:17 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: So much conflicting information ! I just need a good , cheap setup.
the stock setup for your call will work great if everything is new. those C5 and LS1 brakes are very expensive. then you still may have a braking problem.
Old Mar 9, 2010 | 04:54 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Here is what I have on my car and like them a lot. I use these rotors with semi-metallic pads. When I have to brake hard on dry pavement I can and it will plant you in the windshield if you don't have your belt on. The wheels do not lockup unless you hit a sandy or wet spot in the road. I also live and drive in the twisty mountain roads of NC and they haven't failed me yet. I'm just now having to change them after 10 years on the car.
Rotors- http://www.napaonline.com/Search/Det...50012+2012008#
Pads- http://www.napaonline.com/Search/Det...50012+2012008#
Old Mar 9, 2010 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Big brake upgrades and low cost unfortunately don't go hand in hand--and none of them are bolt-ons. Frankly, I haven't heard much complaining about the kits, such as Ed Miller sells. For example, my 1LE set-up, front and rear, functions very well.
As skirkland mentions, a new OE set-up should serve you well, especially since you're looking at Saturday night cruising.
JamesC
Old Mar 10, 2010 | 12:21 PM
Roc THIS's Avatar
Engine: 5.7 TPI
Well with this info, looks like I will be sticking with stock. But most likely getting the drilled and slotted rotors along with some nice pads.
Not doing them yet so If anyone has any other info please chime in .
Old Mar 10, 2010 | 01:06 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Stick with stock brakes, this is not going to be even a daily driver there is no reason to go performance.
NAPA has the stock Calipers and everything you need else, you just got to go talk to the guys at the store.
I don't count rotors and pads as aftermarket or stock, so for that just pick what you are willing to buy.
Old Mar 10, 2010 | 01:29 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
This is a good plan.
Old Mar 10, 2010 | 05:18 PM
one92rs's Avatar
Car: SOLD!!!!!
i dont have rear discs but rear drums as mine is an rs. i logged on to rockauto.com and ordered everything raybestos. went with the professional grade stuff. with new rotors,drums,pads,shoes, and wheel cylinders and springs it came up to 287.00.
Ghettobird52
Jul 5, 2024 11:18 PM
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
MORREALE5
Sep 13, 2015 09:16 PM
dutch930
Sep 11, 2015 06:58 AM
