Help with pad & rotor install!
Old Mar 15, 2010 | 06:15 PM
Maro_lover's Avatar
1991 Z28, 350 TPI, 4 wheel disk brakes.
So I got a brand new pair or rear rotors and pads for the car and started to replace the old stuff today. After fighting with it for a good while trying to figure out how to get the caliper off the rotor I finally got the new rotors on.
Problem:
I can't compress the piston in the caliper enough for the caliper to fit over the pads without the breaks being fully engaged with no travel to be had. I used a giant C-Clamp to compress it all the way and it woulden't go any further.
Solution:
Maybe it's the brake fluid holding the piston out, in turn not letting the piston compress fully?
I didn't have any brake fluid at the time to do a bleed and check it out then.
Any answers guys? I'm about ready to set fire to the jaguar-esk car...Seriously...nothing works the first time on this thing...
Old Mar 15, 2010 | 11:54 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Re: Help with pad & rotor install!
Sitting in the same EXACT spot RIGHT NOW with a 1992 Z28. What the hell???
Fronts are easy. Can't compress the rear enough to go over the rotor.
Come on Third Gen Guru.......
Old Mar 16, 2010 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Following are a couple of links that may be helpful:
https://www.thirdgen.org/forums/brak...ml#post4459314
https://www.thirdgen.org/forums/brak...gone-awry.html
JamesC
Old Mar 16, 2010 | 09:07 AM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Ah, come on. These cars are the best. Always some great help on TGO
Thanks BIG TIME JamesC
Old Mar 16, 2010 | 04:25 PM
Maro_lover's Avatar
yea big thanks man. I have to disagree though, this car requires specialized gm tools to do anything... and the manuals aren't exactly helpful. I do love it though..
Old May 9, 2010 | 07:47 PM
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Originally Posted by JamesC
I'm having the same issue with the iron caliper piston. I can't get it to compress. I have to go bang on it and see if it breaks free. the iron calipers are not nice to work with.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
z28_AJ
Aug 27, 2015 08:59 PM
