help, noise when not breaking.
Old Mar 24, 2010 | 06:40 AM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
i have a 91 camaro 305 tbi, auto, 273 drum brake rear end. my passenger side brake makes a very loud metal on metal grinding sound when im not useing the brake. but if you bearly touch the petal at all it stops??? it does not make the noise on jack stands.....axle bearings maybe?? thanks for your help guys
Old Mar 24, 2010 | 01:19 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: help, noise when not breaking.
It could be. Take the wheel and drum off and see what the shoes look like. Then see how much you can move the axle up and down.
Old Mar 24, 2010 | 01:42 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
sound like front brake wear indicators to me. Your front brakes are probably worn down.
Old Mar 24, 2010 | 02:38 PM
racethesunlive's Avatar
Car: '92 Camaro
This is it.
Had this exact issue last week, loud metal on metal contact when moving, no noise when braking... just replace your pads and you'll be good to go
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
