Another Big Brake upgrade Wheel stud issue
I ordered 2 raybestos 1LE rotors from Rock auto, cut them into hubs and ordered the NAPA 641-1581 stud equivalent in Dorman. The problem is the rotors use 2 different knurl diameters. The dorman are .500" knurl but the other rotor is .550 knurl. Does anyone know of an equivalent 12 mm x1.5 52mm long stud in the .550" knurl?? I'm having a tough time getting a PN.
The other question is, should i try to get another rotor with the .500" knurl? i lose .025" of metal to the outer edge of the hub with the larger knurl, and it looks a bit thin in my opinion.
