ReArEnD
Old Apr 17, 2010 | 12:53 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ReArEnD
ok i swaped out the rearend on my 83 camaro...i put a posi disc brake rearend...but the calipers are shot...:/...
so my question is does anybody kno where can i find brackets to put newer calipers off of a 98 - 2002 camaro?...help plz...
Old Apr 17, 2010 | 02:32 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: ReArEnD
Is this what you need?
http://www.autozone.com/autozone/cat...&parentId=44-0
Old Apr 17, 2010 | 03:26 PM
Car: 1983 Z-28
Engine: 5.7 L
Re: ReArEnD
i think so...lol...
Old Apr 17, 2010 | 03:47 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: ReArEnD
Originally Posted by Al Hasse
they don't carry the backing plate at Autozone for the 98+ brakes.
The one they have listed is incorrect.
the one required is the round part on the ground next to the caliper in the below picture,
Old Apr 17, 2010 | 03:53 PM
Car: 1983 Z-28
Engine: 5.7 L
Re: ReArEnD
o ok thanks...im not sure what im lookin for tho...cuz i was gona buy the new calipers but they told to put newer ones on but all i would need is the mounting bracket...which i dont kno which one it is...:/...
pics or when can i fend it plz...
Old Apr 17, 2010 | 03:54 PM
Zepher's Avatar
Re: ReArEnD
you can't see the picture I posted?
here is the link
http://transamws6.com/pics/ls1_brakes/brakes4.jpg
Old Apr 17, 2010 | 04:23 PM
Al Hasse's Avatar
Re: ReArEnD
Does he need the backing plate or the caliper bracket to attach the caliper to the backing plate? Zepher is right, Auto Zone does not carry the backing plate, but they do carry the caliper bracket. I searched but couldn't find anywhere that does have the backing plates separate from the whole system. Ed Miller on this site (ebmiller) sells a kit, they can also be found on e-Bay where I bought my kit.
Old Apr 17, 2010 | 05:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ReArEnD
83,
If you're unaware, the swap requires much more than just a caliper swap. Of course, you'll need rotors, but also custom parking brake cables and a disc combination valve (the 1LE is recommended); however, since your 83 combination valve very likely has SAE threads and has different line provisions from the metric that you'll need, the situation may become difficult. Then, because you've swapped rear ends and perhaps gear ratios, there's the speedo problem. Also, swapping the backing plate will require axle removal. More info and pics in the following link toward the bottom:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 17, 2010 | 05:26 PM
Zepher's Avatar
Re: ReArEnD
as far as I remember, the backing plate is the caliper bracket, it's not separate, but it might be. it's been a long time since I took my brakes off.
Old Apr 17, 2010 | 08:09 PM
Al Hasse's Avatar
Re: ReArEnD
This is the piece I linked to from Auto Zone. Might be considered part of the caliper by some, but it attaches to the backing plate and holds the pads and caliper in place.
And this is finished, minus lines and cables.
Old Apr 17, 2010 | 08:15 PM
Zepher's Avatar
Re: ReArEnD
I consider that part of the caliper myself.
Old Apr 17, 2010 | 08:49 PM
JamesC's Avatar
Re: ReArEnD
For the 1LE set-up, the manual calls it, Plate, Anchor-LH or -RH. The common term seems to be caliper carrier or perhaps abutment bracket. When you order calipers from parts stores, sometimes they come with the above, sometimes not--at least that's been my experience. Again 1LE, Backing plate to axle flanges, calipers carrier to backing plate:
https://www.thirdgen.org/forums/atta...s-89-shims.jpg
Check post #25 for a pic of the LS1 set-up:
https://www.thirdgen.org/forums/brak...lt1-ls1-2.html
JamesC
Old Apr 19, 2010 | 01:11 AM
Car: 1983 Z-28
Engine: 5.7 L
Re: ReArEnD
ok now this is 2 much work 4 me now...ill just get new calipers and slap them on...
i was just askin where can i get the mountin brackets cuz thats wat a former 3rd gen owner had told me was all i needed and the calipers of course...and that it will bolt on and everything would work...that all i would need 2 put a lil spacer on the back of the mountin bracket and it would bolt on perfect...but idk thats y im askin...
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
