Brake Light - On with E-Brake Applied?
Old Apr 18, 2010 | 10:52 AM
camarobuff1's Avatar
Car: 1992 Z28 Z03
Transmission: AT
Axle/Gears: 3:73
Hey, got my 1988 IROC. Whenever I engage the E-brake, the brake light doesn't come on - the bulb does work though. Just curious if the light should be on when the E-brake is applied for this model year. If so, what would cause it not to light? (again, the bulb DOES work - comes on when I first start it up)
Thanks!
Old Apr 18, 2010 | 11:18 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Brake Light - On with E-Brake Applied?
Bad light socket? Broken trace on the Mylar circuit board on the back of the gauges? Other than that, maybe a bad connection at the harness connector, or the switch at the base of the brake lever.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
