1LE frt. brake noise
Old May 7, 2010 | 12:41 PM
catc's Avatar
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
I've got an annoying noise(chirp,squeak) you can hear with every revolution on my frt. 1 LE setup which i believe i was told this is a C4 setup with a floating caliper.It does not have dust shields so no rubbing there.Anybody have a suggestion. I've used the stuff on the back of the pads, also as soon as you touch the pedal it goes away.
Old May 7, 2010 | 03:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1LE frt. brake noise
could be a wheel bearing
Old May 11, 2010 | 08:53 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Birds In The Wheels
Bearings usually make a continuous screeching sound not just a mere chirp/revolution.
Even if you can’t do brake work, just pull the wheel(s), then the hub cap(s), and make sure there’s grease in there.
The reason you’re hearing a chirp/revolution might be the brake pad wear indicator(s).
Happy Racing!
Spin Me This Week … I’ll Spin You Next Week
Old May 11, 2010 | 09:36 PM
catc's Avatar
Car: 1985 Trans Am
I should mention that this setup was put on last fall and has about 1000 miles on it . It was "new" when installed by myself as a complete unit,unbolt the knuckle and remove complete old and then install . It definitely has grease in the wheel bearing. I work in a GM collision repair shop and have had hundreds of brakes apart and never had this noise, however I'm not experienced in the floating caliper design. I'm not sure if i should disassemble and apply disc brake synthetic lubricant on the metal parts and back of pads. The reason because it was assembled and ready to go when purchased so it should be correct,right. so why the annoying noise and like i said tap the pedal and it goes away.
dbrochard
Sep 19, 2015 08:13 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
