ls1 calipers with c5 rotor?
Old May 13, 2010 | 12:09 AM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Pretty much what the title says. I was just sitting here thinking I would like to try and go alittle bigger with my front brakes. I right now have ls1 calipers rotors cut into hubs. So I havent bought rotors yet.
But is it possible to use ls1 calipers with the 13' c5 rotors? is there a bracket?
Old May 22, 2010 | 03:58 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: ls1 calipers with c5 rotor?
Hmm I know Ed sells kits for C5 caliper on LS1 rotor but I don't know if he has the opposite.
Old May 23, 2010 | 08:55 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Yea, it's possible. The C5 and LS1 caliper are pretty much interchangeable (They might take different size bolts...but that might be the abutment bracket, I can't remember). Basically you need a conversion bracket for whatever rotor you run, so the caliper can be located correctly.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
loud91rs
Oct 5, 2015 10:05 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
