Brake line fitting size?...
Old May 24, 2010 | 04:17 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
One of my Earl's brake lines snapped last night on my GTA. Driver side front broke at the caliper fitting. This is for the 1LE/PBR calipers.
One option is to replace them with the Goodridge lines. However, I'm looking on the Baker Precision Web site and might go with the Aeroquip brake lines that come pre-assembled with female -3 AN fittings.
http://www.bakerprecision.com/earls19.htm
The only other pieces I would need are the correct adapter fittings to attach the hoses to the calipers and the hard lines. I know what size caliper adapters I need, but I'm not sure off-hand what the size of the fitting is on the hard line.
http://www.bakerprecision.com/adapt10.htm
Does anyone know?
This approach is actually looking like a better and more durable solution. It's also looking like it could be cheaper.
TIA!
Old May 24, 2010 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Brake line fitting size?...
i "think" the hardlines are 10mm 1.0, and they are bubble flare
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
