Wilwood GM D52 Dual Piston Calipers
Old May 14, 2010 | 07:45 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I'm slowly gathering pieces to redo my front end... got some Spohn Tubular a arms and steering kit... I have the stock 82 to 83 15" Turbocast wheels, so I can't really upgrade the size of the rotor, but I think I can use these Wilwood calipers with some better / same size rotors to upgrade...
Anyone know if this is a direct bolt on?
http://www.jegs.com/p/Wilwood/Wilwoo...75719/10002/-1
Oh, and what rotor width do these thirdgens have ???
1 inch or 1.28?
Thanks,
Rafael
Old May 14, 2010 | 09:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wilwood GM D52 Dual Piston Calipers
Won't fit. On Wilwood's site look at the drawings for the D52 caliper and the GM Metric caliper. The metrics are what are currently on your car.
Stock rotor thickness is 1" (with iron metric calipers).
RBob.
Old May 14, 2010 | 09:14 AM
luvofjah's Avatar
Thanks for your help & vast knowledge... any other options in keeping with stock rotor size that is worth doing? Thanks in advance,
Rafael
Old May 14, 2010 | 10:15 AM
luvofjah's Avatar
Found these...
http://www.jegs.com/i/Wilwood/950/12...FQyPgwodAjQcJg
Weight savings improvement... But still one piston... don't think it improves much over stock in terms of clamping power...
Raf
Old May 14, 2010 | 12:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Raf
Best bet is to get good brake pads. A few examples would be:
STILLEN Metal Matrix (stillen.com)
Porterfield R-4S
Or an EBC pad (maybe the yellow?)
RBob.
Old May 30, 2010 | 01:06 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I did a C4 swap from ed miller and will never look back. My 2001 s10 has esentially the same delco/moraine front calipers as my 89 iroc did, and it stops pretty poorly as well. On the 89 I went so far as to buy rebuilt delco/moraine calipers, slotted rotors, hawks pads, earls lines, new master, it stopped about the same. They are asking a lot for the caliper size to stop that much car in my opinion.
Old May 30, 2010 | 01:08 AM
norcalz28's Avatar
Those were the brakes that I put together, crap!
Old Jun 1, 2010 | 12:33 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
so these r the oem calipers?
Old Jun 1, 2010 | 10:57 AM
87350IROC's Avatar
Car: 87' IROC
Yes, painted red of course.
ZEEYAA
Apr 16, 2023 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
Night rider327
Oct 9, 2015 09:25 AM
91 SrS
Oct 7, 2015 04:32 PM
skinny z
Oct 5, 2015 06:23 PM
