E-brake Handle Slipping or not grabbing
Old May 28, 2010 | 11:35 AM
Dark91z28's Avatar
Car: 91 Z28
Transmission: WC T-5 (13-52-xxx)
Axle/Gears: Stock
My e-brake handle seems to slip or not grab the e-brake cable gear. is this a normal wear and tear issue or is there another issue. it has done it since my dad had the car. i am just wondering if i go and pick one up from the junkyard how long it will last. Thanks
Old Jun 1, 2010 | 12:41 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Braking The Engagement
The Parking Brake handle is retained in the desired position VIA a ratchet mechanism in the assembly near the pivot point.
The toothed area might be worn, the engagement spring might be weak or broken, there might be a foreign object preventing engagement.
Happy Racing!
I’ve NEVER Hit The Wall! - The Safer Barrier Prevented It
jrdturbo
Mar 31, 2016 02:58 PM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
